This step performs bulk validation and enrichment of address data. It supports integration with two Experian address validation services, allowing you to select the option that best fits your requirements.
Addresses will be cleaned by verifying them against the official postally-correct address files for the relevant country. Cleaned addresses are assigned a match result, based on the accuracy of the original address. You can define layouts specifying the number, content and format of the address output columns. Choose one of the available Additional datasets to enrich your data. The datasets that are available to you depend on your license.
