Credit Reporting
UK Credit Processing Guide (CAIS)
UK credit processing solutions cover several use cases for both consumer and commercial credit reporting. Multiple file formats can be read and written, allowing you to generate a credit file for submission, validate the quality of a file you are already submitting, or convert one file format to another.
Use Aperture Data Studio for UK credit reporting.
US Credit Processing Guide (DataArc 360™)
The DataArc 360™ solution is used to assess data to be provided to the credit reporting agencies to determine if the data satisfies the Metro2® format rules. Metro2® file formats are able to be read and ingested, allowing you to validate and analyze the quality of a file you are already submitting.
Use Aperture Data Studio for US credit reporting.
AUS Credit Processing Guide (CCR)
The ARCA Comprehensive Credit Reporting (CCR) Solution is used to produce and submit CCR submissions by bringing credit data from multiple sources, profiling data, preparing and mapping to CCR schema, validating against CCR rules, and reporting on results.
Use Aperture Data Studio for AUS credit reporting.
