Aperture Match is the next evolution of data matching technology for Aperture Data Studio, designed to empower organizations that seek to match similar records for critical use cases such as duplicate prevention, single customer view or identity resolution.
Why match and deduplicate your data?
Inaccurate or duplicate data can lead to poor customer experiences, wasted marketing spend, and flawed analytics. Data matching helps businesses identify and consolidate duplicate records, whether it's customer profiles, product listings, or supplier information, into a single, accurate view.
This ensures consistency across systems, improves decision-making, and supports compliance with data regulations. Matching is especially critical as data volumes grow and organizations rely on real-time insights.
How can Aperture Match help?
Aperture Match brings a new level of performance and flexibility:
Scalability: Leverage dynamic resource allocation to handle large datasets without sacrificing performance.
Real-time ready: Interact with the duplicate store in real time using real-time workflows, with an optional high-availability setup.
Precision control: Refine clusters manually after they’ve been automatically matched by merging or unmerging records.
Hierarchical clustering: Clearer visibility into the match levels between records, making results easier to understand and analyze.
Aperture Match delivers advanced standardization and intelligent matching algorithms to seamlessly group records with similar data. Its powerful fuzzy matching capabilities mean cleaner, more connected data and smarter insights.
Together with Harmonization, it is used for data cleaning and deduplication with a common use case to create a single customer view or golden record store. The process may also be known as entity resolution.
Matching uses natural language processing (NLP) techniques including:
  • Levenshtein Distance: Measures the number of edits (insertions, deletions, substitutions) needed to transform one string into another.
  • Jaro-Winkler: Weighs similarity based on character transpositions and common prefixes.
  • Soundex / Metaphone: Phonetic algorithms that match words based on how they sound.
Deployment flexibility
Aperture Match’s capabilities are designed to support a wide range of deployment scenarios, including on-premises environments and all major cloud platforms. It can support very large data volumes due to supporting auto-scaling PostgreSQL databases.
The system can be configured for high availability using container orchestration platforms such as Kubernetes.
Bulk operations
Bulk operations in Aperture Match make large-scale data matching simple and efficient. Instead of handling records one by one, you can compare entire datasets against your entity store. Whether you’re doing an initial load to process millions of records or running incremental updates to keep data fresh, bulk matching ensures consistency and saves time.
Real-time operations
Aperture Match fully supports real-time operations and can perform search, update, and delete actions with low latency . Records can be transformed and validated before being added to the duplicate store, ensuring data quality and avoiding adding records that already exist.
Real-time matching helps your business maintain data integrity. For example, as a manager of a retail brand that offers discounts for first-time sign-ups, you can use Aperture Match to check new registrations against existing store records in real time. This prevents duplicate accounts, reduces marketing costs, and ensures accurate single customer views for inbound and outbound communications.
Aperture Match uses the improved and adapted Find Duplicates steps in Aperture Data Studio. If you’re using the previous version of this module - Find Duplicates, please refer to the relevant documentation.
This section covers key concepts of Aperture Match.
Duplicate stores
A duplicate store is a reusable data object in Aperture Data Studio that holds records identified as duplicates during data matching processes. It allows you to persist, manage, and reuse these records across workflows, supporting ongoing data quality efforts.
Cluster and cluster ID
A cluster is a collection of records that have been identified as representing the same entity using the rules defined for the duplicate store. Each top level cluster is identified by a unique cluster ID.
Aperture Match introduces a new approach to clustering. The previous version of Find Duplicates assigned a single match level to an entire cluster which, for clusters with more than two records, potentially hides useful information. Hierarchical clustering allows each record to belong to multiple clusters, each with different match levels. For example, a record could be in an “Exact” level cluster with one other record and also in a “Probable” level cluster with the second record and two other records.
This approach provides greater visibility into the structure of match results, particularly for larger clusters. If you want to see which records are really similar to a record, you can find those that share its “Exact” level cluster or to see records that are at least a little similar, you can look at its “Possible” level cluster. The Possible level cluster will be a superset of the "Exact" level cluster.
Cluster refinement
Cluster refinement allows you more control over how matched records are grouped into clusters. After records are clustered based on the configured matching rules, you can manually refine clusters either by using match level review, which presents clusters containing lower confidence matches (probable or possible) for review, or through selective review, where you can search for specific records or clusters to review and refine.
Match status/level
Each match between two records will have one of the following confidence levels:
Match status Description
Exact (0) Each individual field that makes up the record matches exactly.
Close (1) Records might have some fields that match exactly, and some fields that are very similar.
Probable (2) Records might have some fields that match exactly, some fields that are very similar, and some fields that differ a little more.
Possible (3) Records contain the majority of fields that have a number of similarities, but do not match exactly.
None (4) Records do not match.
Rules and blocking keys
Rules and blocking keys define how records are grouped into clusters within a duplicate store. Aperture Match first creates blocks of similar records, which reduces the number of records that need to be compared. This is done to make the duplicate detection process more efficient. Blocks of records are generated based on a blocking key, which is made up of a combination of record elements.
Every pair of records in the resulting block is then compared using a set of matching rules, which are logical expressions that control the match level returned.
Combinations of matching rules and blocking keys can be stored in Step settings. During Duplicate store configuration, rules and keys can either be entered manually or selected from the available sets in Step Settings.
Additional sets of matching rules can be defined for use when searching the duplicate store using the bulk or real-time Search steps. Search rules can be configured to use all, or a subset of, the blocking keys defined for the store.
Duplicate store objects enable the management and persistence of Duplicate stores in Data Studio. Stores can be both established and updated using the Find duplicates step, and custom settings can be maintained for each store.
When the Find duplicates step is first run the configured store will be established on the Postgres Database. Subsequent runs using the same store will insert or update records in the store. Once the store has been established it can also be used with the Find duplicates query and delete steps as well as Realtime Workflow steps.
Duplicate stores list screen
This screen provides information on each of the stores accessible in the current Space. From here users can create, edit, delete, clear, and set the sharing options of Duplicate stores. If duplicate stores are enabled for cluster management there is an additional option to Review Duplicate stores. Clicking the button at the top of the screen will take you to the screen that displays all reviewable stores. Here you can choose to perform a match level or selective review. More information can be found in the cluster refinement section.
Creation and management
From the Duplicate stores list screen click Create new Duplicate store, or to edit an existing store, select the Edit details action.
The External label (Duplicate store ID) is the name of the store in the Postgres database. This will be generated automatically based on the Duplicate store name but formatted to be compliant with external label restrictions and to be unique in this environment.
Selecting Include timestamp columns will store timestamps for record creation and last update in the Duplicate store. The columns ‘Created timestamp’ and ‘Updated timestamp’ will be included in the output of the Find Duplicates step to indicate when records were created and last modified.
The server location for the Duplicate store defaults to the server configured in Settings > Workflow steps > Find duplicates.
On the next screen click Add blocking keys to either select an existing set of blocking keys (created via Step settings > Find duplicates settings) or enter your blocking keys manually. It is also possible to set the blocking key limit on this screen. This is the limit at which point we ignore the potential matches generated by the blocking key value. Once you have added blocking keys and clicked Apply, you can edit the individual keys to set key specific blocking key limits. It is recommended that you consult with a support representative before changing this value from the default of 500.
To add matching rules for your store, click on Rules and then Add rules and either select an existing set of rules or enter your rules manually. You can set the rules purpose to either Clustering or Search only. Clustering rules are used to form clusters as records are added to the store. Search only rules can be used when searching the duplicate store for matching records using the bulk or Realtime search workflow steps. Only one clustering ruleset can be specified for a store but multiple sets of search only rules can be added to the store. Clustering rules can only be added or edited when the store is not populated whereas search only rules can be added at any time. If you do not require a clustered store there is no need to add clustering rules.
When adding a set of rules, you can select a subset of the available blocking keys to be associated with the rules. All are selected by default. Only the associated blocking keys will be used to generate potential matches.
Selecting Enable cluster management will make the store available for review on the Review Duplicate stores list screen. This setting cannot be changed when the store is populated.
Sharing
You can share Duplicate stores globally or with specific Spaces. From the Duplicate stores list page, click Sharing options. To use a Duplicate store that's been shared with you, click Include from another Space.
Find duplicate steps in Aperture Match
Prepare your data
Before using the Find duplicates step it is important to tag your data to make mapping columns easier. If the columns in your data are tagged already, the Find duplicates step will recognize the tagged columns and automatically assign a relevant Find duplicates column mapping to them. Otherwise, you can manually assign the column mappings based on your knowledge of the data.
This step will only recognize the following:
If your data has columns tagged already, this step will recognize the tagged columns and automatically assign a relevant Find duplicates column mapping to them. Otherwise, you can manually assign the column mappings based on your knowledge of the data.
This step will only recognize the following system-defined tags:
  • Company
  • Address
    • City
    • Country
    • County
    • Locality
    • Postal Code
    • Premise And Street
    • Province
    • State
    • Zip Code
  • Date
  • Email
  • Generic String
  • Phone
  • Name
    • Forenames
    • Surname
    • Title
  • Unique Id
It is important to map your columns as accurately as possible before using the Find duplicates step to make the matching process more efficient. For example, mapping a column as Address when it contains primarily company or name information will lead to less accurate results.
Additionally, using the more granular address element mappings such as Premise and Street and Locality as opposed to the higher level Address mapping (providing your data is divided in such a way) will mean that less effort is required to identify individual address components.
For more information on how Find duplicates utilizes these column mappings, you can refer to the advanced configuration page.
Group IDs
You can apply different rulesets to columns with the same tag by using group IDs.
For example, you may have delivery and billing addresses that you want to treat differently. You would tag both as an address, but create separate group IDs, allowing you to apply different rulesets: only accept an exact match for the billing address, but a close one for the delivery address.
Steps
For Bulk operations refer to the Workflow Steps.
Rules and blocking keys define how records are matched in Aperture Data Studio. To create a new set of rules or blocking keys or view existing ones go to Step settings > Find duplicates settings, or from the Duplicate stores screen either click Create new Duplicate store or select the Edit details action on the action menu of an existing Duplicate store.
Configuration
When configuring blocking keys, you can set the blocking key limit, which is the limit at which point potential matches generated by the blocking key value are ignored. The larger the block, the more comparisons need to be made. A block of 500 records would need almost 125k comparisons as every record needs to be compared with every other record. You can set a limit for each key individually.
When configuring rules, the following options can be selected:
  • The Purpose of the rules:
    • Search only: Search only rules can be used when searching the duplicate store. You can add as many sets of search only rules as you require. If you only specify search rules for a store, no clusters will be formed when the store is populated however if your use case does not require clustering (e.g. duplicate prevention) then maintaining a search only store has performance advantages when adding or updating records.
    • Clustering: Clustering rules are used to form clusters as records are added to the store. Only one set of clustering rules can be defined per store. Clustering rules can also be used when searching the store.
  • Enable cluster management:
    • This option is only available for clustering rules. It allows manual refinement of clusters that have been generated by the configured rules and blocking keys, by users with the assigned capability.
  • Apply huge cluster threshold:
    • This option is only available for clustering rules. For very large clusters of records (500+), processing hierarchical clustering information can be time-consuming. This option allows a limit to be set on the size of cluster for which hierarchical clustering information is provided. If a cluster exceeds the specified limit, all cluster records will be clustered at the loosest level (L3) regardless of the match level between individual records. This can improve performance in heavily clustered stores.
  • Associated blocking keys:
    • You can select a subset of available blocking keys for each set of rules. Only the associated blocking keys will be used to generate potential matches. This extra control means a blocking key can be considered for search but not clustering and vice versa.
Default Find duplicates step settings
Aperture Data Studio provides default Find duplicates step settings for use with the Find duplicates step which can be found in Step settings > Find duplicates settings:
  • Individual: groups records with similar names at similar addresses. For example, GBR_Individual_Default will find individuals in Great Britain. Note that emails, phone numbers, and other identifiers will not be taken into account, but can be added manually.
  • Household: groups records with the same or similar family names at a similar address. For example, GBR_Household_Default will find households in Great Britain.
  • Location: groups records with similar addresses or locations. For example, GBR_Location_Default will find locations in Great Britain.
Default blocking keys and rules are provided for Australia (AUS), Great Britain (GBR), and United States (USA) as detailed in the table below:
Name Summary
AUS_Individual_Default Default Australia individual level rules and blocking keys based on name and address
AUS_Household_Default Default Australia household level rules and blocking keys based on surname (last name) only and address
AUS_Location_Default Default Australia location level rules and blocking keys based on address only
GBR_Individual_Default Default United Kingdom individual level rules and blocking keys based on name and address
GBR_Individual_Alternative Alternative United Kingdom individual level rules and blocking keys based on name and address that may produce better results for large cities
GBR_Household_Default Default United Kingdom household level rules and blocking keys based on surname (last name) only and address
GBR_Location_Default Default United Kingdom location level rules and blocking keys based on address only
USA_Individual_Default Default United States of America individual level rules and blocking keys based on name and address
USA_Household_Default Default United States of America household level rules and blocking keys based on surname (last name) only and address
USA_Location_Default Default United States of America location level rules and blocking keys based on address only
The summary of each step setting is included to explain the purpose of the blocking keys and rules. The details of a step setting can also be viewed when clicked in the Step settings list screen.
Environment and Space level step settings
Find duplicate settings can be configured at an Environment level to be available by all Spaces in the Environment or at Space level:
  • Environment level: Creating Find duplicates step settings in the System Space (go to Space drop down > select System) will make them available to all Spaces within an Environment. This will be useful if all duplicate stores across different Spaces shall use the same rules and blocking keys. Users will automatically see those Find duplicates step settings in their step settings.
  • Space level: Find duplicates step settings created in a single Space, on the other hand, will only be visible in that Space.
Hierarchical clustering allows each record to belong to multiple clusters, each with different match levels. For example, a record could be in an "Exact" level cluster with one other record and also in a "Probable" level cluster with the second record and two other records.
All records in a Duplicate store are assigned a Level All cluster ID. This ID is the ID of the lowest confidence cluster that this record belongs to. The Level All ID can be thought of as the overall cluster ID. All records that match at any level, according to the defined rules, will belong to the same Level All cluster.
If a record does not match any other records, it will still be assigned a Level All ID, but it will be the only record with that ID.
Within a Level All cluster, there could be one or more sub-clusters, where a subset of the records all match each other at a particular confidence level. For example, an overall (Level All) cluster could consist of five records. Records 1 and 2 match at level 0 (the highest confidence match, usually configured to be an exact match), records 3 and 4 match each other and records 1 and 2 at level 1 (close match) and record 5 only matches records 1-4 at level 2 (probable match). In this case you would have a level 2 cluster containing all five records, a level 1 cluster containing records 1 to 4 and a level 0 cluster containing records 1 and 2.
Records in clusters at levels 0, 1 and 2, match every other record in that cluster at that level. However, at level 3, the criterion for a record being part of the cluster is looser, a record only need match one other record in the cluster at level 3 or above.
Aperture Match allows users, including Consumer users, with the Manage duplicate store clusters permission to manually review record clusters that have been matched by rules and blocking keys.
From the Duplicate stores list screen or Dashboard widget, click Review Duplicate stores, which will take you to a screen displaying all of the stores available to be reviewed. Choose the review type (match level or selective review) by clicking on the Actions menu of the store.
Match level review
Match level review automatically selects clusters containing lower confidence matches (L2 and L3) for review. The clusters are presented one by one for review and adjustment. You can drag and drop records to split out records from a cluster or confirm low confidence matches.
Once you have completed your changes for a cluster, click Accept clusters to commit the new cluster arrangement to the store and the next cluster will then be displayed for review.
When all clusters containing L2 or L3 links have been reviewed, the review status for the store will show as Complete on the list screen.
Selective Review
In contrast to match-level review, selective review is to manually retrieve clusters at any level for review. Selecting Perform selective review from the Actions menu takes you to the start of the Selective review wizard from where records can be searched.
Searching the store
There are multiple ways to search the store for records on this screen:
  • Record ID - enter the unique ID of records to find the record.
  • Cluster ID - enter the unique ID of record clusters to find the records in those clusters.
  • Record fields - Select the column names from your Duplicate store and enter search values for those columns to find records.
  • Element types - Similar to record fields but using the data types of the columns, rather than the names of the columns.
The Record fields and Element types searches operate based on the predefined search rules, requiring sufficient input data to successfully locate the matching record.
Clicking the search button will return any records that match the search and display the results in the table. Select the records to be reviewed. You are able to perform multiple searches and select various records to review at once.
Once all needed records are selected they can be viewed by clicking the Show selected button at the top of the table. This will clear the table of search results and only display the selected records. Deselect not wanted records from this view. To go back to the search results of the last performed search click Show search results.
Once all reviewable records are selected click Review selections at the bottom of the screen to go to the review page.
Reviewing selections
The review screen will display all previously selected records, as well as all records that are in the same clusters as those selected records. You can now drag and drop records and arrange them into clusters, or split them out into separate records, as desired.
Once you are finished with the arrangement of records and clusters, clicking Accept clusters will save the changes and exit out of the screen. Clicking Accept clusters and select again takes you back to the search screen where you are able to continue to search for records in order to review them.
Match level exceptions
After accepting clusters, match level exceptions are created to represent the overriding of the rules based matching results with the custom changes. This will be displayed with a symbol beside the records that have been affected. Those can be viewed on the selective review search screen. Clicking the symbol will give details about the committed exception.
Viewing match level exceptions
When viewing match level exceptions for a specific record, the data for that record is displayed at the top of the screen. Below you find information about all records that now have match level exceptions with the selected record in the Duplicate store. You can see the match level determined by the rules, and the updated match level that the exception now prescribes for the pair or records. These paired records are grouped according to the date and time they were submitted, and the user who submitted them.
Overview
Data Studio provides default blocking keys that you can use to run the Find duplicates step. However, you can create your own custom rules and blocking keys that are tailored to your needs.
Blocking keys and rulesets are designed and specified using elements - a representation of your input data after it has been mapped in the Find duplicates step and gone through the initial standardization process. Find out about elements.
The standardization process also creates additional versions of these elements to assist further - known as modifiers. Modifiers can correct, enhance or derive many known terms that appear in the input. For example, a DERIVED modifier may be created when the element was not contained in the input but the standardization process was able to determine the value (e.g. COUNTY can sometimes be derived from the LOCALITY and POSTCODE input). Find out about modifiers.
Elements can also be put into specific groups to separate them from other elements of the same type. This is especially important when you want to create blocking keys or rules that treat them as separate entities, such as cross-field matching.
These elements, modifiers and groups (along with blocking key algorithms and rule comparators) can then be combined to make your own blocking keys and rules specific to your design and data.
The table below covers the available elements that can be used when designing blocking keys and rules, together with the possible modifiers and rule comparators that can be used with them. Note that blocking key algorithms are not listed here because they apply to all elements.
Element Description Example Comparators Modifiers
Title Title Mrs
  • ExactString
  • Default
  • StandardSpelling
  • StandardAbbreviation
Forenames Given name(s) and any initials John
  • ExactString
  • ForenameCompare
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
  • RootName
Surname_Prefix Surname prefix De la
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
  • StandardSpelling
Surname Surname with prefix Smith
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
  • RootName
Full_Name Concatenation of forenames and surname (including prefix if present) John O'Connor
  • ExactString
  • TransposedNameCompare
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
  • RootName
Surname_Suffix Surname suffixes Junior
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
  • StandardSpelling
Gender Gender Female
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
Honorifics Honorifics Ph.D
  • ExactString
  • Levenshtein
  • JaroWinkler
  • Default
  • StandardSpelling
Company Organization name Experian Ltd
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
Building_Description Building name and type George West House
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
Building_Number Building number 43
  • ExactString
  • PremiseCompare
  • Default
SubBuilding_Number Sub-building number 2
  • ExactString
  • PremiseCompare
  • Default
SubBuilding_Description Sub-building name First-floor
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
SubBuilding_Type Sub-building type Flat
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
  • StandardSpelling
MinorStreet_Number Street number 34th
  • ExactString
  • PremiseCompare
  • Default
MinorStreet_Predirectional Street pre-directional South
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
  • StandardSpelling
MinorStreet_Description Street name Carnaby
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
MinorStreet_Type Street descriptor Street
  • ExactString
  • Levenshtein
  • JaroWinkler
  • NumericCompare
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
  • StandardSpelling
MinorStreet_Postdirectional Street post-directional South
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
  • StandardSpelling
PoBox_Number PO box number 79
  • ExactString
  • Levenshtein
  • JaroWinkler
  • Default
PoBox_Description PO box description PO Box
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
  • StandardSpelling
DoubleDependentLocality A small locality such as a village, used to identify an address where a street appears more than once in a dependent locality Kingston Gorse
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default/Derived
  • StandardSpelling
DependentLocality Smaller locality used to identify an address where a street appears more than once in a locality East Preston
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default/Derived
  • StandardSpelling
Locality A larger locality, such as a town or a city Cambridge
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default/Derived
  • StandardSpelling
Province A larger area of a country, contains multiple localities Cambridgeshire
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default/Derived
  • StandardSpelling
Country Country name United Kingdom
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
Postcode Postal code or ZIP code 'SW4 0QL' or '20521 9000'
  • ExactString
  • PostcodeCompare
  • Default/Derived
  • StandardSpelling
Generic_String Generic string ab-1234cdef
  • ExactString
  • Levenshtein
  • JaroWinkler
  • NumericCompare
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
Date ISO date in the format YYYY-MM-DD 1980-06-21
  • ExactString
  • DateCompare
  • Default
Phone Phone number (01234) 567890
  • ExactString
  • Levenshtein
  • JaroWinkler
  • Default
Email Email address john.smith@domain.com
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
Email_Local Local part of email address john.smith
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
Email_Domain Email domain domain.com
  • ExactString
  • Levenshtein
  • JaroWinkler
  • DoubleMetaphone
  • Soundex
  • NYSIIS
  • Default
Hash Hash value of all normalised input fields within a group 8bf14557574b8793aae648fc1b0280c3
  • ExactString
  • Default
The table below covers the available element modifiers that can be used. See the elements table to find out which modifiers can be used with which elements.
Modifier Operation Example
(Default) The element classified from the input in a cleaned form, normalised to remove diacritics and converted to upper case. Supplied: 123 High Road
MINORSTREET_TYPE -> ROAD
StandardSpelling The element converted to a standard spelling (contains Derived value when available). Supplied: 123 High Road
MINORSTREET_TYPE.STANDARDSPELLING -> ROAD
StandardAbbreviation The element converted to the standard abbreviation. Supplied: 123 High Road
MINORSTREET_TYPE.STANDARDABBREVIATION -> RD
Derived A derived value that was inferred from other information in the input address. Supplied: 123 High Road, London, E1 2EZ
PROVINCE.DERIVED -> GREATER LONDON
RootName The root name of the input name. Supplied name: Alex
FORENAMES.ROOTNAME -> ALEXANDER
Any element can be used multiple times in an input to represent separate or unique sets of information. For example, the input may include multiple:
  • street numbers, street names and postcodes (e.g. a delivery and a billing address)
  • forenames and surnames (e.g. a primary account holder and a spouse)
  • generic strings (e.g. an account and a customer reference)
  • dates (e.g. a date of birth and a registration date)
  • phone numbers (e.g. a cell phone number and a landline number)
  • email addresses (e.g. a personal and a work email)
Using groups in blocking keys
You may want to create different blocking key specifications for different groups of the same element type, or use the same blocking key specification for multiple groups of the same element type. To do this, you need to add elementGroups to your element specification within your blocking key design. Find out more about elementGroups.
For example, if you have a billing and a delivery address and you want to have two different blocking key specifications for them that have different designs, you would add the following to each address element of the group within your blocking key designs:
"elementGroups":["BillingAddress"]
"elementGroups":["DeliveryAddress"]
Alternatively, if you wanted to use the same blocking key specification for both groups, you would add the following to each address element of the group within that single blocking key design:
"elementGroups":[
    "BillingAddress",
    "DeliveryAddress"
The blocking key specification examples below are taken from the default blocking keys available in Data Studio, and have been amended to show how they would be used for the two cases above.
Two differently designed blocking key specifications for two different groups of the same element type:
    "description": "SurnameMinorStreetNumberLocality",
    "countryCode": "GBR",
    "elementSpecifications": [
        "elementType": "SURNAME",
        "algorithm": {
          "name": "INITIAL"
        "includeFromNChars": 1
        "elementGroups": ["BillingAddress"],
        "includeFromNChars": 1,
        "truncateToNChars": 5
        "elementType": "LOCALITY",
        "elementModifiers": [
          "STANDARDSPELLING",
          "DERIVED"
        "includeFromNChars": 2,
        "truncateToNChars": 30
    "description": "POBoxNumberLocality",
        "elementType": "POBOX_NUMBER",
        "elementGroups": ["DeliveryAddress"],
          "STANDARDSPELLING",
          "DERIVED"
The same blocking key specification for two different groups of the same element type:
        "elementType": "POSTCODE",
        "elementGroups": ["BillingAddress","DeliveryAddress"],
          "STANDARDSPELLING"
        "includeFromNChars": 5,
        "truncateToNChars": 7
Using groups in rules
You may want to handle the items listed above separately during rule evaluation. To do this, you need to prefix the rule with a hash symbol, followed by the group name in square brackets, followed by a period, followed by the rest of the rule.
For example, if you have a billing address and a delivery address and you want to evaluate them separately, you could write rules such as the ones below.
Match.L0 = {Name.L0 & #[Billing].Address.L0 & #[Delivery].Address.L0}
Match.L1 = {Name.L1 & (#[Delivery].Address.L1 | #[Billing].Address.L1)}
By default, this will mean that the two different groups will use the same underlying rules (in the case above, the same address rules). To use different rules for two groups that are of the same element type, you can use theme rules that are then utilized at the top level.
Match.L0={#[Billing].LooseAddressRule.L0 & #[Delivery].StrictAddressRule.L0}
LooseAddressRule.L0={Postcode.L0}
StrictAddressRule.L0={MinorStreet_Number & Postcode.L0}
MinorStreet_Number.L0={PremiseCompare[ExactMatch]}
Postcode.L0={PostcodeCompare[Part1Match] & PostcodeCompare[Part2Match]}
In the above example, two different theme rules have been used to evaluate an address (one being stricter than the other since it requires both the premises number AND postcode to be compared), but each is only used with one group as defined at the match level.
You can also specify more than one group in any rule, such as the example below. This will perform cross-field matching.
Match.L0 = {Name.L0 & #[Billing,Delivery].Address.L0}
Blocking Keys
The Find duplicates step uses blocking keys to create blocks of similar records to assist with the generation of suitable candidate record pairs for scoring via a ruleset.
Blocks are created from records that have the same blocking key values. Blocking keys are created for each input record from combinations of the record's elements that have been keyed. Keying is the process of encoding individual elements to the same representation so that they can be matched despite minor differences in spelling. To be effective, blocking keys should represent a range of contact data sub-element combinations.
Data Studio provides default blocking keys tuned for name and address matching for the Find duplicates step. However, you can modify these or create your own to suit your needs.
All blocking keys have to be built in the structure below.
Element Description
description (optional) A descriptive name for the blocking key, for example "MyBlockingKey".
countryCode (optional) An informational code that can be used to imply the country that the blocking key is to be used with (the value does not affect processing in any way). If you require blocking keys conditionally generated, see the validCountries element.
validCountries (optional) An array of ISO3 country codes for which the blocking key is valid. If this element is present and the standardized record has a country code, then it must match one of the country codes in the array - otherwise the blocking key won't be generated. For example:
"validCountries":["GBR","IRL"]
elementSpecifications An array of elements that are to be used in the key, created as part of the initial standardization process.
Blocking keys are created using the list of elements in order.
For example, the key FORENAMES+SURNAME+MINORSTREET_NUMBER would be created from the array below:
"elementSpecifications":[
{ "elementType":"FORENAMES" },
{ "elementType":"SURNAME" },
{ "elementType":"MINORSTREET_NUMBER" }
Each element within elementSpecifications has to then be built in the structure below:
Element Description
elementType The element to use in the blocking key. See the list of available elements and examples for each.
elementGroups (optional) The group(s) that the element belongs to. If this isn't supplied, the default group will be used.
This is required when you have more than one of the same element type (e.g. multiple phone numbers) that you want to treat separately. Find out about groups.
The example below specifies multiple groups for a single element type:
"elementGroups":[
"HomeAddress",
"WorkAddress"
elementModifiers (optional) An array of element modifiers to use. This list is processed in order and the first populated element will be used. If no modifier is specified/found, the default value of the element will be used. See the list of available modifiers, which elements they apply to and examples for each.
The benefit of element modifiers is to use a more standardized and uniform version of the element, to better assist with blocking together records that may not look the same in their string representation but could still very much be intended to represent the same thing.
The example below will use the standard spelling form of the element if available, otherwise the derived form. If neither are found, the default value for the element will be used.
"elementModifiers":[
"STANDARDSPELLING",
"DERIVED"
algorithm (optional) Keying algorithm used to key the element. These are useful for blocking as they can cause similar elements to be blocked together even if their original form is not identical. For example, the SOUNDEX algorithm can be used to block similar sounding values (since they will have the same SOUNDEX key) even if they do not look the same.
Defined algorithms have to have a name and can also have an optional set of additional properties. For example, the SUBSTRING algorithms require start, end and/or length.
"algorithm": {
"name": "MIDDLE_SUBSTRING",
"properties": {
"start": 2,
"end": 6
See the list of available algorithms (and any associated properties) and examples for each.
includeFromNChars (optional) Only include the keyed element in the blocking key if it is N or more characters in length.
If specified, a blocking key will not be created when the configured element does not meet this criterion.
For example, if this is set to 5 on the POSTCODE element, any postcodes found to be less than 5 characters in length will not be included in the blocking key, therefore the entire blocking key will not be created for that record.
truncateToNChars (optional) Truncate the keyed element to N characters in length.
For example, if this is set to 10 on the SURNAME element, any surnames longer than 10 characters will be included into the blocking key but cut at the 10th character.
The algorithms below are available for use in blocking key specifications, and apply to all non-numeric elements. If no algorithm is specified, the SIMPLIFIED_STRING algorithm is used.
Name Description Keyed Example Additional properties
NO_CHANGE No modification performed, and whitespaces retained ANDREW J -> ANDREW J
SIMPLIFIED_STRING Whitespace removed ANDREW J -> ANDREWJ
DOUBLE_METAPHONE Double metaphone algorithm on all words ANDREW J -> ANTR
DOUBLE_METAPHONE_FIRST_WORD Double metaphone algorithm on the first word only ANDREW J -> ANTR
NYSIIS NYSIIS algorithm ANDREW J -> ANDRAJ
SOUNDEX SOUNDEX algorithm ANDREW J -> A536
CONSONANT Only include consonants ANDREW J -> NDRWJ
INITIAL Initial character only ANDREW J -> A
START_SUBSTRING Substring from the start of the value ANDREW J ("length":3) -> AND "length": <integer>
MIDDLE_SUBSTRING Substring from defined start position to defined end position ANDREW J ("start":2, "end":5) -> NDRE "start": <integer>,
"end": <integer>
END_SUBSTRING Subtring from the end of the value ANDREW J ("length":3) -> W J "length": <integer>
CONSONANT and SOUNDEX support the following character sets:
  • Basic Latin (ASCII)
  • Latin-1 Supplement
  • Latin Extended-A
  • Latin Extended Additional
All other key types support the following Latin character sets:
  • Latin Extended-A
  • Latin Extended-B
  • Latin Extended-C
  • Latin Extended-D
  • Latin Extended-E
  • IPA Extensions
  • Phonetic Extensions
  • Phonetic Extensions Supplement
Let's use the default blocking keys in Data Studio for more advanced examples of blocking key design:
   "description": "FullZipCode",
   "countryCode": "USA",
         "STANDARDSPELLING"
       "includeFromNChars": 9
This first blocking key specification is comprised of just the POSTCODE element, using the STANDARDSPELLING element modifier, and restricting the keys created from it in that they must be at least 9 characters long.
This will result in the generation of candidate score pairs for every record in the data with the same zip and +4 code.
The sample input USA zip codes below would therefore create the following keys with this blocking key specification:
  • 90210-8560 ⇒ 902108560 - complete example, with the correct number of characters
  • 90210-08560 ⇒ 902100856 - truncated example, with the final 0 cut off
  • 90210 ⇒ <null> - no blocking key generated due to min. length of 9 being unsatisfied
This second blocking key specification below is a little more advanced - it combines a few elements together and uses various modifiers and algorithms, as well as different character number restrictions.
        "elementType": "FORENAMES",
          "ROOTNAME"
        "algorithm": {
        "truncateToNChars": 10
        "algorithm": {
          "name": "DOUBLE_METAPHONE"
This will result in the generation of candidate score pairs for every record in the data with the same forename root name double metaphone value, surname double metaphone value, and premises number.
  • The first element defined is FORENAMES and uses:
    • the ROOTNAME element modifier
    • the DOUBLE METAPHONE_FIRST_WORD algorithm on that root name
    • key restrictions where the forename must be at least 1 character long, and then stop including characters in the key after the 10th
  • The second element defined is SURNAME without any element modifier, then uses:
    • the DOUBLE METAPHONE algorithm on the surname
    • key restrictions where the surname must be at least 1 character long, and then stop including characters in the key after the 10th
  • The third (and final) element defined is MINORSTREET_NUMBER, and uses:
    • no element modifiers or element algorithms
    • key restrictions where the number must be at least 1 digit long, and then stop including characters in the key after the 5th
The sample name and addresses below show what those blocking keys would look like:
MRS VAL JONES, 45 MAIN ROAD, LONDON, E1 2AS
  • FORENAMES = VAL
    • Modifier: ROOTNAME of VAL = VALERIE
    • Algorithm: DOUBLE_METAPHONE_FIRST_WORD of VALERIE = FLR
    • Length restriction: Length of FLR = 3, and 3 is greater than 1 and less than 10 so satisfies restriction
FLR
  • SURNAME = JONES
    • Modifier: <none>
    • Algorithm: DOUBLE_METAPHONE of JONES = JNS
    • Length restriction: Length of JNS = 3, and 3 is greater than 1 and less than 10 so satisfies restriction
JNS
  • MINORSTREET_NUMBER = 45
    • Modifier: <none>
    • Algorithm: <none>
    • Length restriction: Length of 45 = 2, and 2 is greater than 1 and less than 5 so satisfies restriction
45
Therefore, the final key generated for this address is: FLRJNS45.
MR JOHNNY ANDERSON-THOMPSON, 123456 HIGH STREET, BRIGHTON, BN1 3SX
  • FORENAMES = JOHNNY
    • Modifier: ROOTNAME of JOHNNY = JOHNATHON
    • Algorithm: DOUBLE_METAPHONE_FIRST_WORD of JOHNATHON = JN0N
    • Length restriction: Length of JN0N = 4, and 4 is greater than 1 and less than 10 so satisfies restriction
⇒ JN0N
  • SURNAME = ANDERSON-THOMPSON
    • Modifier: <none>
    • Algorithm: DOUBLE_METAPHONE of ANDERSON-THOMPSON = ANTR
    • Length restriction: Length of ANTR = 4, and 4 is greater than 1 and less than 10 so satisfies restriction
⇒ ANTR
  • MINORSTREET_NUMBER = 123456
    • Modifier: <none>
    • Algorithm: <none>
    • Length restriction: Length of 123456 = 6, and 6 is greater than 1but more than 5 so truncate at the 5th character
⇒ 12345
Therefore, the final key generated for this address is: JN0NANTR12345.
PAUL SMITH, HANCOCK BUILDING, GRACE AVENUE, NOTTINGHAM
  • FORENAMES = PAUL
    • Modifier: ROOTNAME of PAUL = PAUL
    • Algorithm: DOUBLE_METAPHONE_FIRST_WORD of PAUL = PL
    • Length restriction: Length of PL = 2, and 2 is greater than 1 and less than 10 so satisfies restriction
⇒ PL
  • SURNAME = SMITH
    • Modifier: <none>
    • Algorithm: DOUBLE_METAPHONE of SMITH = SM0
    • Length restriction: Length of SM0 = 3, and 3 is greater than 1 and less than 10 so satisfies restriction
⇒ SM0
  • MINORSTREET_NUMBER = null
    • Modifier: <none>
    • Algorithm: <none>
    • Length restriction: Length of null = 0, which is NOT greater than 1 so key restriction NOT satisfied
⇒ <null>
Because not all the blocking key specification has been satisfied in this case (due to the missing premises number in the input), no blocking key is generated for this record from this blocking key specification.
Rules
Whilst blocking keys are used to generate suitable candidate pairs of input records, rules are then used to score those pairs together and cluster together any that are considered a good enough match.
You can modify the default rulesets or even create your own. Before you do though, we recommend that you review the concepts below:
  • Rules take the following form: <rule reference>=<expression>
  • A rule reference consists of a rule name followed by a "." and followed by a match level (e.g. MyRule.L0)
  • An expression may take multiple forms:
    • Low-level expression - operates on the elements within a record.
    • Higher-level expression - composed of references to other rules.
  • A ruleset consists of a combination of three rule types which increase in specificity from match, to theme, to element, as illustrated in the diagram below.
    • Match and theme rules are comprised of references to rules from the level below.
    • Element rules are comprised of rules that are set on specific data elements, such as a postcode or a building number. These element rules can use special comparators depending on the element type.
All rules have a rule reference on the left-hand side.
A rule reference takes the following format: <rule name>.<match level>
The rule name may be any of the following:
  • "Match" (match rule).
  • A custom identifier (theme rule). Must begin with an alphabetical character and may contain alphanumeric characters, underscores, and hyphens.
  • Element (single element rule).
The match level can be: L0, L1, L2, or L3. Note that you can override these values by using aliases.
The right-hand side of a rule:
  • Is always surrounded by curly brackets: { }
  • May contain logical operators: & and |
Expressions may be nested and logical operators combined (parentheses are required), e.g. MyRule.L2 = {((RuleA.L3 & RuleB.L2) | (RuleA.L2 & RuleB.L3)) | RuleC.L0}
Element rules include the element and the allowed result set (enclosed in [ ] and comma-separated) and may also include an optional element modifier and/or comparator.
Any theme or element rule may also optionally include a group from the input mappings, which is defined by using a hash symbol before the group name. For example:
#MyFieldGroup.PostcodeTheme.L0 = {Postcode[ExactMatch]}.
You can also specify a default country in the rules file. This lets the Find duplicates step know what country to use when processing and standardizing data if:
  • you're not using a country tag when mapping your data columns or
  • the country field for a record is blank.
To specify a default country, add @default.country=<countryiso> to the top of the rules file (where <countryiso> is the ISO 3166-1 alpha-3 country code). For example: to set Australia as the default country, add: @default.country=AUS.
You can use the default rules provided with the Find duplicates step as the basis for customization since they already contain the correct default country value.
There are 4 match levels that can be used within each rule specification:
Match level Description
L0 Each individual field that makes up the record matches exactly.
L1 Records might have some fields that match exactly, and some fields that are very similar.
L2 Records might have some fields that match exactly, some fields that are very similar, and some fields that differ a little more.
L3 Records contain the majority of fields that have a number of similarities, but do not match exactly.
Note that you can override these level names with your own custom names. To do so, you have to use the expression define <Alias> as <Match level> at the top of the rules file, e.g.
define High as L0.
Match.High={Name.High & Address.High}
When working with match levels, note that:
  • They will be evaluated in order from L0 through to L3, stopping at the first level that passes.
  • A rule level will evaluate as true if the same rule has evaluated as true for a higher level. For example, if MyRule.L1 is true, then MyRule.L2 and MyRule.L3 will also be true.
  • Records will be considered a match and they will be clustered together, provided that any of the defined top level overall rule match levels evaluate to true.
  • Every rule must include a match level as part of the rule reference.
Rules are evaluated as follows:
  1. Match rules first (Match.<Match Level>).
  2. Left to right.
  3. Lazily.
Three rule types can be defined:
Match rules
This is the highest rule level, defining an overall match between two records. A match rule is made up of references to other rules.
At least one match rule must be defined for a successful matching job.
  • Example: Match.L0={Name.L0 & Address.L0} (Name.L0 and Address.L0 have been defined separately).
You can combine rule references into compound logical expressions. This way, you have complete control over the logic used to determine matches.
  • Example: Match.L1={(Name.L0 & Address.L0) | (Name.L0 & Email.L0 & Phone.L0)}
Theme rules
Theme rules represent the next level down, after match rules.
Similar to a match rule, a theme rule is made up of references to other rules. The theme rule name must begin with an alphabetical character and may contain alphanumeric characters, underscores and hyphens. The rule name cannot contain "Match" or the set of reserved elements.
  • Example: Address.L0={Premise.L0 & Street.L0 & Locality.L0 & Postcode.L0}
The rule references within the expression can either be other theme rules, or low-level element rules.
Element rules
Element rules are the most granular of rules. They can be used to specify how to compare individual elements within a record. Elements are basic units of data that comprise an overall theme. For example, postcode and premise could be elements of an address theme.
Rules are designed to evaluate and compare elements using special comparators. The table below covers the available comparators you can use.
If you want to know which comparators are available for which elements, see the elements table.
Comparator Results
ExactString (default comparator)
  • ExactMatch: Strings match exactly e.g. "John Smith" & "John Smith"
  • OnePopulated: The field is populated for one of the records e.g. "John Smith" & ""
  • NonePopulated: The field is not populated for either of the records e.g "" & ""
  • NoMatch: The strings are both populated but are not an exact match e.g. "John Smith" & "John Doe"
ForenameCompare
  • ExactMatch: Strings match exactly, ignoring hyphens e.g. "Sarah-Jane" & "Sarah Jane"
  • InitialVsFullName: An initial or initials match to the full name e.g "S J" & "Sarah Jane"
  • FirstNameMatch: The first name of a multiple-name forename matches e.g "Sarah" & "Sarah Jane"
  • InvertedNameMatch: All the names in a multiple-name forename match but are in a different order e.g "Jane Sarah" & "Sarah Jane"
  • AnyNameMatch: Any name matches in a multiple-name forename e.g "Jane" & "Sarah Jane"
Plus all ExactString (default comparator) results.
  • ExactMatch: The forename(s) and surname match exactly to the transposed version e.g. "John Smith" & "Smith John"
  • PartialMatch: Only one part of the name matches to the transposed version e.g. "John Smith" & "Smith Paul", or "John Smith" & "Jones John"
  • NoMatch: Neither the forename(s) or surname match exactly to the transposed version e.g. "John Smith" & "Jones Paul"
PremiseCompare
  • StartMatch: Premise matches the start of a premise range e.g. "12" & "12-15"
  • StartMatchAndEncapsulated: Premise ranges match at the start and one encapsulates the other e.g. "12-15" & "12-16"
  • EndMatch: Premise matches the end of a premise range e.g. "15" & "12-15"
  • EndMatchAndEncapsulated: Premise ranges match at the end and one encapsulates the other e.g. "13-16" & "12-16"
  • Encapsulated: Premise or premise range is encapsulated by the other e.g. "12" & "11-16"
  • Overlapped: Premise ranges overlap each other e.g. "12-15" & "14-18"
  • NumberMatchWithTrailingAlpha: Premise numbers match and one record has a trailing alpha e.g. "12" & "12a"
  • NumberMatchWithDifferingAlpha: Premise numbers are a perfect match but trailing alpha is different e.g. "12a" & "12b"
DateCompare
  • DayMonthReversed: Matches dates where the day and month are reversed eg "2017-06-03" & "2017-03-06"
  • MonthYearMatch: Matches dates where only the month and year match eg "2017-06-03" & "2017-06-04"
  • DayMonthMatch: Matches dates where only the day and month match eg "2017-06-03" & "2016-06-03"
  • DayYearMatch: Matches dates where only the day and year match eg "2017-06-03" & "2017-07-03"
  • YearMatch: Matches dates where only the year matches eg "2017-06-03" & "2017-07-04"
  • <n>DaysDifference: Matches dates that differ by up to n days
  • <n>WeeksDifference: Matches dates that differ by up to n weeks (n * 7 days)
  • <n>MonthsDifference: Matches dates that differ by up to n calendar months
  • <n>MaxCharsDifference: Matches dates where up to n characters can be different (equivalent to levenshtein distance for dates)
PostcodeCompare
  • Part1Match: Records match to the first part of the postcode e.g. "HA2 9PP" & "HA2 5QR"
  • Part2Match: Records match to the second part of the postcode e.g. SM1 9PP" & "HA2 9PP"
  • PostcodeCompatible: The first part of the postcode for both records matches, and the second part is populated in one record only e.g. "HA2 9PP" & "HA2"
Levenshtein Depending on specified comparison type, either:
  • <Minimum %>: The minimum Levenshtein percentage to provide a match (integer between 0-100) e.g. setting the LevenshteinPercent result to 90 would return a match for "John Smith" & "Joan Smith"
Or
  • <Maximum distance>: The maximum Levenshtein distance to provide a match (integer). e.g. setting the LevenshteinDistance result to 1 would return a match for "John Smith" & "Joan Smith"
JaroWinkler
  • <Minimum %>: The minimum Jaro-Winkler distance percentage to provide a match (integer between 0-100). e.g. setting the JaroWinkler result to 95 would return a match for "John Smith" & "Joan Smith"
NumericCompare
  • ExactMatch: The numeric part of the strings match exactly e.g. "5th" & "5th"
  • OnePopulated: Only one of the records contains a numeric value. The other record is either blank or does not contain a numeric value e.g. "5th" & "", or "5th" & "fifth"
  • NonePopulated: Both records are either blank or do not contain numeric values e.g. "fifth" & "fifteenth"
  • NoMatch: Both values are numeric but do not match e.g. "5th" & "15th"
  • <n>: Both values are numeric and adding n to the lower value produces a value greater than or equal to the higher value
  • <n%>: Both values are numeric and adding n percent of the higher value to the lower value produces a value greater than or equal to the higher value
DoubleMetaphone
    The DoubleMetaphone comparator ignores all digits. When applied to an element where alphanumeric data is expected it should be combined with a NumericCompare rule.
  • ExactMatch: The primary Double Metaphone codes for both strings are the same e.g. "Smith" & "Smythe"
  • AlternateCodeMatch: The strings have matching Double Metaphone codes, taking into account alternate codes e.g. "Smith" & "Schmidt"
  • FirstWordMatch: The first words of each string have matching Double Metaphone codes e.g. "Mary Anne" & "Marie"
Soundex
    The Soundex comparator ignores all digits. When applied to an element where alphanumeric data is expected it should be combined with a NumericCompare rule.
  • ExactMatch: The Soundex codes for both strings are the same e.g. "Smith" & "Smythe"
NYSIIS
    The NYSIIS comparator ignores all digits. When applied to an element where alphanumeric data is expected it should be combined with a NumericCompare rule.
  • ExactMatch: The NYSIIS codes for both strings are the same e.g. "Jan" & "John"
Filters may be used within rules to select only part of the specified string element. Insert one (or chain several) filter(s) between the element and the comparator. All existing comparators may be used, including Levenshtein.
Selecting a sub string
The SubString filter allows you to select a portion of a string. It has two integer parameters, the first determines where the selection will start and the second the number of characters to select.
The first parameter selects the offset in the string at which to start. When zero or positive it selects an offset from the start of the string. When negative it selects an offset from the end of the string. For example -1 selects the last character, -2 from the second last character, etc.
The second parameter determines the number of characters to select. When zero, all characters to the end of the string will be selected. When positive, the supplied number of characters will be selected. When negative, the supplied number of characters will be removed from the end of the selection.
Boundary Conditions: If the second parameter is positive and greater than the number of characters available in the string (after applying the offset from the first parameter) then only the available characters will be selected. Otherwise, if the supplied parameters cannot select any characters then an empty string will be produced from the filter.
All of the examples below will produce a match.
Record Generic String
Record 1 123-TR
Record 2 123-RM
GenericStringMatch.L2 = {Generic_String.SubString[0,3].[ExactMatch]}
Record 1 TR-123
Record 2 RM-123
GenericStringMatch.L2 = {Generic_String.SubString[3,0].[ExactMatch]}
(notice that 3,0 will remove the first 3 characters, leaving the remainder of the string)
Record 1 R-4AB
Record 2 N-4AR
GenericStringMatch.L2 = {Generic_String.SubString[2,-1].[ExactMatch]}
(produces a string starting at offset 2 and removing the last character)
Record 1 R-4567-AB
Record 2 N-7643227-AB
GenericStringMatch.L2 = {Generic_String.SubString[-2,0].[ExactMatch]}
(produces a string starting at the offset 2 characters from the end)
Record 1 MM-John Smith
Record 2 CC-Joan Smith
GenericStringMatch.L2 = {Generic_String.SubString[3,0].Levenshtein[90%]}
Selecting an item from a delimited string
DelimitedField can be used to select a field from a string delimited by one or more characters. The delimiter is defined as a java regular expression specified as the first argument, while the second argument is an integer that specifies the field to select. Since character escapes are now allowed in the rule syntax it is necessary to double escape any string literals that use characters reserved for regular expressions.
Record 1 A-4567-AB
Record 2 A-7643227-AB
GenericStringMatch.L2 = {Generic_String.DelimitedField["\\-",0].[ExactMatch]}
(selects the first item of an array of strings delimited by the '-' character, so both values will be 'A'. Note the double escaping in use. The first is to escape possible special character codes, the second because the string is a regular expression)
Record 1 First item-4567-ATTR
Record 2 Second item-4567-ATTR
GenericStringMatch.L2 = {Generic_String.DelimitedField["\\-",1].[ExactMatch]}
(selects the second item of an array of strings delimited by the '-' character, so both values will be '4567'. Note the double escaping in use. The first is to escape possible special character codes, the second because the string is a regular expression)
Using 'Contains'
The 'Contains' filter selects the shorter value from both records if the value in the shorter is contained within the longer, otherwise the values pass through the filter unchanged.
Record 1 Blah
Record 2 I contain Blah here
GenericStringMatch.L2 = {Generic_String.Contains.[ExactMatch]}
Chaining filters
Filters may be chained together. There's no limit to the number, but we recommend using no more than three.
Record 1 First item-4588-ATTR
Record 2 Second item-4599-ATTR
GenericStringMatch.L2 = {Generic_String.DelimitedField["\\-",1].SubString[0,2].[ExactMatch]}
These are element rule examples that focus on how different elements, modifiers and comparators can be used when designing the rules:
Initial vs full name
Record Forename Surname
Record 1 Robert Brooke
Record 2 R Brooke
Name.L2 = {Forenames.ForenameCompare[InitialVsFullName] & Surname[ExactMatch]}
Minor street number
Record MinorStreet_Number MinorStreet_Description MinorStreet_Type
Record 1 123 Burnthouse Lane
Record 2 123a Burnthouse Lane
StreetAddress.L1 = {MinorStreet_Number.PremiseCompare[NumberMatchWithTrailingAlpha] & MinorStreet_Description[ExactMatch] & MinorStreet_Type.StandardAbbreviation[ExactMatch]}
Postcode
Record MinorStreet_Description MinorStreet_Type Locality Postcode
Record 1 Hints Road Tamworth B78 3AB
Record 2 Hints Road Tamworth B78 3AT
Address.L2 = {Building_Number[ExactMatch] & MinorStreet_Description[ExactMatch] & Locality[ExactMatch] & Postcode.PostcodeCompare[Part1Match]}
Cross-field matching
Cross-field matching allows you to match across multiple fields of the same type to find potential duplicates.
For example, if your data consists of three phone number fields (e.g. home, work and mobile number), you can configure the Find duplicates step to find potential phone number matches across all three of them.
To configure the Find duplicates step to perform cross-field matching, you have to set up your blocking keys and rulesets in such a way that your groups of similar data will be blocked and scored together.
Example
You have multiple address fields (home and billing) and want to identify potential duplicates where the billing address of one record matches the delivery address of another record.
RECORD ID NAME HomeAddress BillingAddress
ADDRESS LOCALITY POSTCODE ADDRESS LOCALITY POSTCODE
1 John Smith 1 High Street London SW4 0QL 48 Webber Road Brighton BN3 1EJ
2 John Smith 12 Acacia Avenue London E1W 2BB 1 High Street London SW4 0QL
Using the default rules and blocking keys for GBR and modifying them to consider these two addresses in separate groups (HomeAddress and BillingAddress), the two records will not be matched together since the home address for the two records will not block together or evaluate as a match in the rules. Similarly, the two records would still not match together based on the billing address group since the billing addresses are also different.
The desired behavior is for the following cross-field operations to be performed (with the operation in bold causing a match using the above example):
  • HomeAddress 1 vs. HomeAddress 2
  • BillingAddress 1 vs. BillingAddress 2
  • HomeAddress 1 vs. BillingAddress 2
  • BillingAddress 1 vs. HomeAddress 2
To achieve this, add: "elementGroups": ["HomeAddress","BillingAddress"] to the blocking keys for each address component of each blocking key definition and #[HomeAddress,BillingAddress] to the address rules of the final match level rules.
Blocking keys
The blocking key definition below is from the default GBR individual blocking keys, combining the surname initial, street number and locality into a blocking key. By default, this will create keys for a single address. However, it can be modified to create keys for multiple addresses using the HomeAddress and BillingAddress below:
       "algorithm": {
         "name": "INITIAL"
       "elementGroups": ["HomeAddress","BillingAddress"],
         "STANDARDSPELLING",
         "DERIVED"
This will now cause two blocking keys to be generated for every record:
  • SURNAME_Initial + HomeAddress_MINORSTREET_NUMBER + HomeAddress_LOCALITY
  • SURNAME_Initial + BillingAddress_MINORSTREET_NUMBER + BillingAddress_LOCALITY
Using the sample data, the following blocking keys will be created:
  • Record 1
    • S1LONDON
    • S48BRIGHTON
  • Record 2
    • S12LONDON
    • S1LONDON
Since the first and last keys are identical, records 1 and 2 will now be blocked together and identified as a candidate pair for scoring in the rules.
Rules
The rule snippet below is from the default GBR individual ruleset that has been amended to include cross-field support as an example:
Match.Exact={Name.Exact & #[HomeAddress,BillingAddress].Address.Exact}
This will now cause the following rule evaluations to be performed:
Fields A Fields B Result
Record1_Name + Record1_HomeAddress vs. Record2_Name + Record2_HomeAddress FALSE
Record1_Name + Record1_BillingAddress vs. Record2_Name + Record2_BillingAddress FALSE
Record1_Name + Record1_HomeAddress vs. Record2_Name + Record2_BillingAddress TRUE
Record1_Name + Record1_BillingAddress vs. Record2_Name + Record2_HomeAddress FALSE
The third case will be true since the home address of record 1 matches the billing address of record 2 as an exact match.
